User mod -b2 stair controller latest release?
I am trying to find the user mod for stair case animation in the latest release and its not there. Was it removed? Do I have to add it separately ? ( if so how?/ where?)
Secondly if i can get it to work I am trying to create the following ‘effect’ - for each segment or each step I want the lights to come in from teh edges to the centre then from the centre outwards to go off.
On
Off
Can anyone help?
I see 2 entries in the current Usermod source: Animated_Staircase and Stairway_wipe_basic.
I’m guessing the 2nd one may be closer to what you’re trying to accomplish.
Thanks I was able to get the use rmod installed "Animated _staircase’ however that was back in march and I have completely forgotten how to do it …
I am having some troubles with it ( it works one direction but not the other no idea how to trouble shoot it)
the stairway wipe basic sounds good but I would have no idea how to modify code to trigger from PIR sensors…
Haven’t used that one myself, but from what I read you should be able to embed the API triggers into presets and have the PIRs trip those presets.
Just use pre-compiled binaries from @srg74
How do I get the pre compiled Binary - can any one help me? I am sure I got one 8-10 months ago when I started the project - I have reason to believe it may be glitchie or was not the latest- as my stair do not shut off and cat be triggered properly from both ends… so I am looking to reinstall and start fresh and try again … I am not a coder/ developer / engineer and have been muddling through and tried to follow the step by step guide to compile wled source and add in the stair case mod but was unsuccessful - I’m happy to send a few bucks some ones way if they can help me getting this going @blazoncek??? @SRG74???
Here is the output from my api - but the stairs are not going in the other direction (only trigger from bottom) and do not shut off after each step is triggered … only after all steps trigger?
{“on”:true,“bri”:255,“transition”:5,“mainseg”:0,“seg”:[{“id”:1,“start”:0,“stop”:19,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:2,“start”:19,“stop”:38,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:3,“start”:38,“stop”:57,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:4,“start”:57,“stop”:76,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:5,“start”:76,“stop”:95,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:6,“start”:95,“stop”:114,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:7,“start”:114,“stop”:133,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:8,“start”:133,“stop”:152,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:9,“start”:152,“stop”:171,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:10,“start”:171,“stop”:190,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:11,“start”:190,“stop”:209,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:12,“start”:209,“stop”:228,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:13,“start”:228,“stop”:247,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“id”:14,“start”:247,“stop”:266,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[0,0,255],[0,0,0],[0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0}]}
