Usermode staircase when using effect mode
I had a problem with the usermode stair case when running the effect. running solid mode 1 color has no problem, both delay and time settings are working smoothly, otherwise when running effect mode, there is a delay and time error, hope you guys can help, thanks a lot
Hi. Can you please explain how to activate the staircase mode? Thanks for you.
