im getting {“error_code”:-1009} when i try and access wled from a browser on esp32 - the error is displayed on the ‘web page’ the rest of the page is blank. restarted and power cycled numerous times. This is on a ws8211b strip. however it is functioning absolutely fine via Homeassistant. running WLED 0.14.0-b1 . is there a way to OTA flash another way other than via web UI ? otherwise its a trip up the ladders and its too cold for all that TIA
OTA should be possible as long as your ESP has >2M flash.
If not, or if it doesn’t work, you need to serially flash it.
Hi , thankyou for replying
i cant access the web ui to flash via OTA unless there is an alternative to the WLED UI to do it OTA, I will just have to get up the ladders and do it physically. or is there a way to do it through homeassistant ?
If you can’t get to the UI, you need to pull it down for serial flashing.
