What do i need for 20m adressable RGB 60 led/m strip?
Hello,
I’m new here, and I wanted to ask what do I need and how do I connect everything.
My plan is to connect two 10m 24V WS2811 RGB strips from BTF to a ESP32 Controller and using WLED for two or more channels (I want to use SignalRGB).
I know I need a 24V/15A/360W PSU and some JST Jumper cables.
I just don’t know if what I plan is possible.
Will the data reach the last LED?
Will the voltage drop at the end?
Do I need more components for it to work?
I appreciate all the help i can get
Chers
Without going into interfacing the ESP32 with the strips: Please follow the guidance by BTF.
If I recall correctly, then you shall provide power every 5m or so. Please use adequate gauge too, the connectors they provide appear to be on the skimpy side for 5 and 12VDC applications.
