WLED 0.11.0 - Questions
  1. Why did the button stop turning on and off the backlight? (on 0.10.2 it worked)
  2. How to switch effects using a button, as it could be done in 0.10.2?
    How do you fix it?
The person who updates this firmware, can you answer and write an example of how to make the effect switch (presets) a button??
In 0.11.0, the button still works the same as always.
Please, how can I assign to the presets switch button?
Another question: today the board itself switched to the AP mode, why can it be? And why does setting up the IC switched on after the restart change the value by disabling? Please help…
Did you check here?
Yes… But I don’t understand how I can switch the presets button. I’ve been using the macro Pl=~. Now I don’t know how I can keep that on.
Pretty much like before…
Thank you! Thank you.)) I did it!
