Controlling Govee curtains with WLED isn’t natively supported, as WLED primarily focuses on LED strips and not smart curtains. However, some users have had success with workarounds. Here are a few approaches you could consider:
Smart Home Integration: If you have a smart home hub (like Home Assistant), you might be able to integrate both WLED and Govee devices, allowing you to create automations that control both.
IFTTT or Similar Services: Use IFTTT (If This Then That) to create triggers based on actions in WLED that could control the Govee curtains. This would require both devices to be compatible with IFTTT.
Custom Scripts: If you’re comfortable with coding, you might explore creating a custom script using APIs or MQTT to communicate between WLED and your Govee curtains.
Third-Party Apps: Some third-party applications might offer broader compatibility, allowing you to control various smart devices, including Govee.
If you have specific goals for controlling the curtains or any particular features you want to implement, let me know, and I can help you brainstorm further!
