Wled controlling Sonoff basic
Some years ago I followed a youtube video to make a Sonoff basic control a string of LED’s with Wled. When I flashed the Sonoff I used WLED version 11 ESP01 160 Bin.
All worked great for years until the Home Assistant integration required Wled version 14 or above.
This evening I flashed the Sonoff with WLED_0.14.4_ESP01_160.bin, Wled runs fine however it won’t control the Sonoff relay (nor will pressing the Sonoffs button make the relay work). There is a new menu called ‘user mods’ when I am not sure about! Is anyone able to help?
The youtube build video - https://www.youtube.com/watch?v=94JmrMYiT_o&t=19s
The youtube wled configure video - https://www.youtube.com/watch?v=pOW17tnIHeM&t=71s
The LED string is connected to GPIO 2
Regards
James
Did you set the gpio pin for the relay in Led Preferences?
(22 is not likely to be the value you need for your controller)
Thanks, I found this setting needs to be 12 to make it work.
Regards
