WLED setup worked on next day leds not working at all
Hey community,
I setup my wled controller and strip for the first time yesterday it worked fine, I went to bed powered all off, started in on next day, now all the lights are off all the time. I can connect to the controller successfully but leds are all off. I tried to reset everything not working, I installed all updates, not working. I hope someone had the same situation already?
Hardware I am using:
  • Controller: ESP32 WLED Digital LED Controller with Mic / UART (GLEDOPTO) GL-C-010WL-D
  • LEDs: ICEVER WS2812B 5050 RGB White 300D DC5V
  • Power supply: Weishuo Power Supply AC100-240V to 5V 10A 50W
Thanks so much for the support! :slight_smile:
maybe that is just bad hardware? gled are not known for great quality. could also just be relay pi configuration
So you think the controller broke? I have a second one to test with it. What do you mean with relay pi config?
there was an “n” lost. relay pin can be configured in settings, if the controller has a “relay” to enable the outputs, it needs to be configured or outputs will not be powered.
