Newbie Desperately Needs Help
I’m trying to get my LED strip working using WLED. I’ve watched a ton of YouTube’s and think I’m following their instructions but have not been successful. I am at wits end.
Here’s the hardware I’m working with:
• WS2812B ECO LED Strip from BTF-Lighting (BTF-6V-WS2812E-30L-W-L)
• AC to DC Adapter 5V 3A Power
• Songhe ESP8266 NodeMCU CP2102 ESP-12E
• ESP WROOM 32 ESP32 Development Board 2.4GHz WiFi Dual Cores
Microcontroller
Here’s What I’ve Done:
  1. Successfully flashed each of the ESP controllers with WLED, modified the WIFI
    setting and can access the controllers on my WIFI network.
  2. Connected the LED strip to the controller with jumper wires connecting the White
    (-) lead to the GRD pin, the green (data) lead to the D4 pin and the red (+) lead to
    the VIN pin, in that order.
    a. As soon as I connect the positive lead, here’s the LED lights I get:
    i. # 1 & 2 - green-ish
    ii. #3 - very dim green dot.
    iii. #4 - not lit
    iv. #5 & 6 - white
    v. #7-35 - Not Lit
    vi. #36 – White
    vii. #37 to End of Strip – Not Lit
    My WLED Settings
    • LED Output = WS281X
    • Color Order = GRB
    • Length = 15 (Trying to light the first 15 LEDs on the strip)
    • GPIO = 16 (What WLED install defaulted to)
    • All other setting left to default install
    What I’m Encountering
    • The WLED interface seems to have no control over the LED strip
    o Changing the Length setting from 30 (default) to 15 – No effect
    o Changing the GPIO from 16 (default) to 2 – When I click on the WLED Power
    button, I get a slight blink on the controller board but, no change in the LED
    lights.
    • Changing the power source from my laptops USB to the AC to DC Adapter 5V 3A
    Power has no effect
    • Switching the controller boards – no change
    Any help would be greatly appreciated.
First, you should not be making connections with the power on. :wink:
D4 is usually GPIO2. Either change to that in LED preferences, or move your wire to whatever GPIO16 is on your board.
