Wled dmx sr
Hello everyone. I ask you for help, to spend some of your personal time. My knowledge in programming is very weak. I tried to do everything according to the instructions, but nothing worked… I want to use WLED + DMX + SoundReactive. Can someone compile the file for me?
I don’t know if I can leave my email address here, but I’ll try… voffcheggg@gmail.com
I would be grateful for any help.
Hi @Voffcheggg
Wled got the DMX E131 onboard at the standard installation
so where is the problem just connect to the Device via the IP
and send the Signals as E131 protocoll and this workes fine
as you like to CHECK use Xlights as it comes with the WLED Devices as Controller so plug and play
Be shure your cionfiguration of the Nodes is working
Thank you. But this particular connection is very important to me. WLED + DMX Out + SoundReactive. This can only be done by compiling (I can’t do it, errors appear)
