hello
i wanna use wled hub75 on ESP32-S3-WROOM-1-N16R8 but neither of bin file that are released wont work on my esp32
i tested wled 16.0.1 esp32-s3-16MB-opi-Hub75
Wled-16.0.1-esp32- hub 75
is that because my esp not supported for hub75 or im using wrong bin file?
hub75 is still a new feature and not fully fletched out. it requires compile time settings so you probably need to compile yourself with proper settings for your board and panel pins.
what does “won’t work” mean exactly — board won’t boot, or it boots n wled runs but the panel shows nothing? those are two totally different problems.
if it won’t boot: full erase first, leftover partitions from whatever was on there before mess things up. n16r8 needs the opi psram build which is the one u tried, so that part is right.
if wled runs but panel is dark: the prebuilt hub75 bin assumes the default pin wiring from the usermod. if ur panel is hooked to different pins, no release bin will ever match — that’s when u actually have to compile with ur own pin defines. so before diving into platformio, check ur wiring against the default hub75 pins in the usermod readme.
FYI my fork allows for dynamic selection of several known Hub75 boards including dynamic selection of half/quarter scan panels, dynamic chaining and dynamic selection of shift registers.
I do not provide compiled binaries, though.
