WLed with a TM1814 24V Stripe
Hello anyone,
Can anyone tell me how I got a TM1814 Led-Stripe connected to a D1 Mini, thought about using an LM393, or is there a level shifter for 24v?
thank you for your help
Ace
To the best of my knowledge, all addressable strips are using 5V logic, so you should not need a special level shifter.
You forgot to mentioned that better use shifter for converting signal from 3.3v to 5v. Power could be different but logic level still 5V TTL
