Wled, ws2812b, wemos d1 mini, odd and flaky behavior. Help!
Ok, first attempt at a wled project. I have a 5 meter strip, ws2812b RGB LED’s.
I am attempting to control them with a Wemos D1 mini, esp2866.
I have it all powered with a 5v, 10a power brick.
I have the green data lead from the led strip to pin D4 on the D1 Mini.
I have pos and neg from the led strip direct to the power source pos and neg.
And I have the same neg connected to gnd on the D1.
I then have the Pos also connected to 5v on the D1.
I flashed it with wled 0.12.0 at first.
I Soldered that all up, and fired it up for the first time, worked perfectly! Only the first few lights came on, orange, which seems by design. I did the wifi setup, and things seemed great. I configured the number of LEDs in the strip (150 if im figuring properly) and started toying with the colors and patterns. Everything seemed to work well. I then linked it to the WLED integration with homeassistant, and that too worked well.
Then as I was showing my creation to the kids, suddenly it went unresponsive, and the first 5 lights on the strand would periodically blink. 1 through 4 are white, the 5th green. No longer on my wifi, no longer hosting its own AP. just dead, and blinking this color pattern.
I reset the power, and that seemed to help the first time, but it happened again shortly after.
I reflashed with 0.13.0b0 just to see, and after the reflash, and reconfig, it seemed to be working again. I did a lot of switching of colors and patterns to see if I could break it again, first through wled’s web ui, then through home assistant, seemed solid.
I unplugged it to finally mount my creation on the wall where I wanted to hang it, and now it;s back to the flashing pattern, and I cant get it to respond.
You can see the flashing here: https://photos.app.goo.gl/MTxvuJ8DY6JfKJBo7
Sorry if this is a bit rambly, but I’m not sure where to go next. Thanks!
here’s an update.
Today I reflashed 0.12.0, since flashing the beta didnt help, figured i’d go back to stable.
I flashed with the mini connected to USB, not my external power.
after the flash, it came up in unconfigured form, the first 30 or so led’s lit orange. I could control the leds, everything seemed fine, i configured wifi, then i was able to control wled over my network, good to go.
as soon as I connect the external power source, it starts the flashing loop again, where it flashes those first 5 led’s.
If i connect the usb cable, while its still connected to the external power, i see in the console output, just repeated stack dumps. So I’m guessing that the flash happens each time its rebooting.
Today, I did remove the wires I had used for the power to the mini, and replace them with some nicer wire, wondering if maybe there was an issue there. Did not help.
Here is a video better depicting the problem.
I have more Mini’s, should I try another one? Is there something up with my power source? The source is a 5v 10A power brick.
ive also tried to see if I can figure out what to do with this output, the console gives me an exception dump… and mentions an exception decoder… Can I analyze this somehow to get some indication of what’s wrong?
[13:18:48]--------------- CUT HERE FOR EXCEPTION DECODER ---------------
[13:18:48]
[13:18:48]Exception (0):
[13:18:48]epc1=0x4026ddcc epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
[13:18:48]
[13:18:48]>>>stack>>>
[13:18:48]
[13:18:48]ctx: sys
[13:18:48]sp: 3fffdce0 end: 3fffffb0 offset: 0190
[13:18:48]3fffde70:  4010581c 40105819 00000000 00000000
[13:18:48]3fffde80:  400005e1 00000000 00000000 00000000
[13:18:48]3fffde90:  4026ddcc 00000033 0000001e 00000000
[13:18:48]3fffdea0:  40105822 04000102 00000000 00000001
[13:18:48]3fffdeb0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffdec0:  0000001a 00000018 04000102 40105804
[13:18:48]3fffded0:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffdee0:  00000000 00000000 00000000 00000000
[13:18:48]3fffdef0:  00000000 00000000 00000000 00000000
[13:18:48]3fffdf00:  00000000 00000000 00000000 00000000
[13:18:48]3fffdf10:  00000000 00000000 00000000 00000000
[13:18:48]3fffdf20:  00000000 00000000 00000000 00000000
[13:18:48]3fffdf30:  00000000 00000000 00000000 00000000
[13:18:48]3fffdf40:  00000000 00000000 00000000 00000000
[13:18:48]3fffdf50:  00000000 00000000 00000000 00000000
[13:18:48]3fffdf60:  00000000 00000000 00000000 00000000
[13:18:48]3fffdf70:  00000000 00000000 00000000 00000000
[13:18:48]3fffdf80:  4010581c 40105819 00000000 00000000
[13:18:48]3fffdf90:  400005e1 00000000 00000000 00000000
[13:18:48]3fffdfa0:  4026ddcc 00000033 0000001e 00000000
[13:18:48]3fffdfb0:  40105822 04000102 00000000 00000001
[13:18:48]3fffdfc0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffdfd0:  0000001a 00000018 04000102 40105804
[13:18:48]3fffdfe0:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffdff0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe000:  00000000 00000000 00000000 00000000
[13:18:48]3fffe010:  00000000 00000000 00000000 00000000
[13:18:48]3fffe020:  00000000 00000000 00000000 00000000
[13:18:48]3fffe030:  00000000 00000000 00000000 00000000
[13:18:48]3fffe040:  00000000 00000000 00000000 00000000
[13:18:48]3fffe050:  00000000 00000000 00000000 00000000
[13:18:48]3fffe060:  00000000 00000000 00000000 00000000
[13:18:48]3fffe070:  00000000 00000000 00000000 00000000
[13:18:48]3fffe080:  00000000 00000000 00000000 00000000
[13:18:48]3fffe090:  4010581c 40105819 00000000 00000000
[13:18:48]3fffe0a0:  400005e1 00000000 00000000 00000000
[13:18:48]3fffe0b0:  4026ddcc 00000033 0000001e 00000000
[13:18:48]3fffe0c0:  40105822 04000102 00000000 00000001
[13:18:48]3fffe0d0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffe0e0:  0000001a 00000018 04000102 40105804
[13:18:48]3fffe0f0:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffe100:  00000000 00000000 00000000 00000000
[13:18:48]3fffe110:  00000000 00000000 00000000 00000000
[13:18:48]3fffe120:  00000000 00000000 00000000 00000000
[13:18:48]3fffe130:  00000000 00000000 00000000 00000000
[13:18:48]3fffe140:  00000000 00000000 00000000 00000000
[13:18:48]3fffe150:  00000000 00000000 00000000 00000000
[13:18:48]3fffe160:  00000000 00000000 00000000 00000000
[13:18:48]3fffe170:  00000000 00000000 00000000 00000000
[13:18:48]3fffe180:  00000000 00000000 00000000 00000000
[13:18:48]3fffe190:  00000000 00000000 00000000 00000000
[13:18:48]3fffe1a0:  4010581c 40105819 00000000 00000000
[13:18:48]3fffe1b0:  400005e1 00000000 00000000 00000000
[13:18:48]3fffe1c0:  4026ddcc 00000033 0000001e 00000000
[13:18:48]3fffe1d0:  40105822 04000102 00000000 00000001
[13:18:48]3fffe1e0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffe1f0:  0000001a 00000018 04000102 40105804
[13:18:48]3fffe200:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffe210:  00000000 00000000 00000000 00000000
[13:18:48]3fffe220:  00000000 00000000 00000000 00000000
[13:18:48]3fffe230:  00000000 00000000 00000000 00000000
[13:18:48]3fffe240:  00000000 00000000 00000000 00000000
[13:18:48]3fffe250:  00000000 00000000 00000000 00000000
[13:18:48]3fffe260:  00000000 00000000 00000000 00000000
[13:18:48]3fffe270:  00000000 00000000 00000000 00000000
[13:18:48]3fffe280:  00000000 00000000 00000000 00000000
[13:18:48]3fffe290:  00000000 00000000 00000000 00000000
[13:18:48]3fffe2a0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe2b0:  4010581c 40105819 00000000 00000000
[13:18:48]3fffe2c0:  400005e1 00000000 00000000 00000000
[13:18:48]3fffe2d0:  4026ddcc 00000033 0000001e 00000000
[13:18:48]3fffe2e0:  40105822 04000102 00000000 00000001
[13:18:48]3fffe2f0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffe300:  0000001a 00000018 04000102 40105804
[13:18:48]3fffe310:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffe320:  00000000 00000000 00000000 00000000
[13:18:48]3fffe330:  00000000 00000000 00000000 00000000
[13:18:48]3fffe340:  00000000 00000000 00000000 00000000
[13:18:48]3fffe350:  00000000 00000000 00000000 00000000
[13:18:48]3fffe360:  00000000 00000000 00000000 00000000
[13:18:48]3fffe370:  00000000 00000000 00000000 00000000
[13:18:48]3fffe380:  00000000 00000000 00000000 00000000
[13:18:48]3fffe390:  00000000 00000000 00000000 00000000
[13:18:48]3fffe3a0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe3b0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe3c0:  4010581c 40105819 00000000 00000000
[13:18:48]3fffe3d0:  400005e1 00000000 00000000 00000000
[13:18:48]3fffe3e0:  4026ddcc 00000033 0000001e 00000000
[13:18:48]3fffe3f0:  40105822 04000102 00000000 00000001
[13:18:48]3fffe400:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffe410:  0000001a 00000018 04000102 40105804
[13:18:48]3fffe420:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffe430:  00000000 00000000 00000000 00000000
[13:18:48]3fffe440:  00000000 00000000 00000000 00000000
[13:18:48]3fffe450:  00000000 00000000 00000000 00000000
[13:18:48]3fffe460:  00000000 00000000 00000000 00000000
[13:18:48]3fffe470:  00000000 00000000 00000000 00000000
[13:18:48]3fffe480:  00000000 00000000 00000000 00000000
[13:18:48]3fffe490:  00000000 00000000 00000000 00000000
[13:18:48]3fffe4a0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe4b0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe4c0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe4d0:  4010581c 40105819 00000000 00000000
[13:18:48]3fffe4e0:  400005e1 00000000 00000000 00000000
[13:18:48]3fffe4f0:  4026ddcc 00000033 0000001e 00000000
[13:18:48]3fffe500:  40105822 04000102 00000000 00000001
[13:18:48]3fffe510:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffe520:  0000001a 00000018 04000102 40105804
[13:18:48]3fffe530:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffe540:  00000000 00000000 00000000 00000000
[13:18:48]3fffe550:  00000000 00000000 00000000 00000000
[13:18:48]3fffe560:  00000000 00000000 00000000 00000000
[13:18:48]3fffe570:  00000000 00000000 00000000 00000000
[13:18:48]3fffe580:  00000000 00000000 00000000 00000000
[13:18:48]3fffe590:  00000000 00000000 00000000 00000000
[13:18:48]3fffe5a0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe5b0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe5c0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe5d0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe5e0:  4010581c 40105819 00000000 00000000
[13:18:48]3fffe5f0:  400005e1 00000000 00000000 00000000
[13:18:48]3fffe600:  4026ddcc 00000033 0000001e 00000000
[13:18:48]3fffe610:  40105822 04000102 00000000 00000001
[13:18:48]3fffe620:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffe630:  0000001a 00000018 04000102 40105804
[13:18:48]3fffe640:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffe650:  00000000 00000000 00000000 00000000
[13:18:48]3fffe660:  00000000 00000000 00000000 00000000
[13:18:48]3fffe670:  00000000 00000000 00000000 00000000
[13:18:48]3fffe680:  00000000 00000000 00000000 00000000
[13:18:48]3fffe690:  00000000 00000000 00000000 00000000
[13:18:48]3fffe6a0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe6b0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe6c0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe6d0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe6e0:  00000000 00000000 00000000 00000000
[13:18:48]3fffe6f0:  4010581c 40105819 00000000 00000000
[13:18:48]3fffe700:  400005e1 00000000 00000000 00000000
[13:18:48]3fffe710:  4026ddcc 00000033 0000001e 00000001
[13:18:48]3fffe720:  40105822 04000102 00000000 00000001
[13:18:48]3fffe730:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffe740:  0000001a 00000018 04000102 40105804
[13:18:48]3fffe750:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffe760:  00000000 00000000 00000000 00000000
[13:18:48]3fffe770:  69e95000 00000000 00000000 00000000
[13:18:48]3fffe780:  00000000 00000000 00000000 00000002
[13:18:48]3fffe790:  00000000 00000000 00000001 00000001
[13:18:48]3fffe7a0:  b4f4a800 0000f839 0000a800 00000000
[13:18:48]3fffe7b0:  d13cf839 0000d13c a279f072 0000001f
[13:18:48]3fffe7c0:  00000000 4028247a 3fffe882 00000000
[13:18:48]3fffe7d0:  0000b722 ffffffe8 9b95d088 00000001
[13:18:48]3fffe7e0:  0000b722 00000000 ffffffe8 ffffffff
[13:18:48]3fffe7f0:  00000000 00000000 40282459 000ea81c
[13:18:48]3fffe800:  4010581c 40105819 00000000 00000000
[13:18:48]3fffe810:  400005e1 0000000b 00000000 00000000
[13:18:48]3fffe820:  4026ddcc 00000033 0000001e ffffffff
[13:18:48]3fffe830:  40105822 04000102 00000000 00000001
[13:18:48]3fffe840:  fbf8ffff 04000002 3feffe00 00000100
[13:18:48]3fffe850:  0000001a 00000018 04000102 40105804
[13:18:48]3fffe860:  3fffc100 3fff0938 00000000 00000000
[13:18:48]3fffe870:  00000000 00000000 00000001 40006545
[13:18:48]3fffe880:  00000000 00000000 00000000 40006545
[13:18:48]3fffe890:  00000001 00000001 00000000 40006589
[13:18:48]3fffe8a0:  00000000 3fffe922 00000000 4028284e
[13:18:48]3fffe8b0:  40282862 00000001 00000000 00000000
[13:18:48]3fffe8c0:  3fffe8d3 00000000 00000000 40006545
[13:18:48]3fffe8d0:  01fe0000 0000000d 00000059 00000000
[13:18:48]3fffe8e0:  00000000 00000000 00000000 00000001
[13:18:48]3fffe8f0:  4027cb5f 00000001 fffffffe 00000000
[13:18:48]3fffe900:  00000001 00000008 3fffe922 0000000c
[13:18:49]3fffe910:  4010581c 40105819 00000000 00000000
[13:18:49]3fffe920:  400005e1 00000004 4000bd9c 00000000
[13:18:49]3fffe930:  4026ddcc 00000033 0000001e 00000004
[13:18:49]3fffe940:  40105822 04000102 00000000 00000001
[13:18:49]3fffe950:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3fffe960:  0000001a 00000018 04000102 40105804
[13:18:49]3fffe970:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3fffe980:  3ffe90a0 4023ab29 00000020 4010139a
[13:18:49]3fffe990:  3ffe90a0 4023b398 3fffe9d0 40257405
[13:18:49]3fffe9a0:  3fffea00 3fffea00 00000001 4023ab36
[13:18:49]3fffe9b0:  3ffe90a0 00000000 3fff06b8 4024c608
[13:18:49]3fffe9c0:  3fffe9e0 00000000 3fff06b8 4021169d
[13:18:49]3fffe9d0:  00000004 00000000 4023ab0c 4023b1c0
[13:18:49]3fffe9e0:  3ffe9762 00000000 4024110c 3fff0314
[13:18:49]3fffe9f0:  3ffeff44 00000000 3ffeff14 4022f498
[13:18:49]3fffea00:  00000000 00000000 00000000 00000000
[13:18:49]3fffea10:  00000000 00000000 00000000 00000000
[13:18:49]3fffea20:  4010581c 40105819 00000000 00000000
[13:18:49]3fffea30:  400005e1 00000000 00000010 402493ec
[13:18:49]3fffea40:  4026ddcc 00000033 0000001e 40100914
[13:18:49]3fffea50:  40105822 04000102 00000000 00000001
[13:18:49]3fffea60:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3fffea70:  0000001a 00000018 04000102 40105804
[13:18:49]3fffea80:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3fffea90:  000000ed 00000020 3fffefc0 00000000
[13:18:49]3fffeaa0:  3fff1aec 00000000 00000003 00000000
[13:18:49]3fffeab0:  ffffffff ffffffff ffff0002 00000000
[13:18:49]3fffeac0:  00000000 00000000 00000000 00000000
[13:18:49]3fffead0:  00000000 00000000 00000000 00000000
[13:18:49]3fffeae0:  ffffffff 00ffffff 00000000 00000000
[13:18:49]3fffeaf0:  00000000 00000000 00000000 00000000
[13:18:49]3fffeb00:  00000000 00000000 00000000 00000000
[13:18:49]3fffeb10:  00000000 00000000 00000000 00000000
[13:18:49]3fffeb20:  00000000 ff000000 ffffffff ffffffff
[13:18:49]3fffeb30:  4010581c 40105819 ffffffff ffffffff
[13:18:49]3fffeb40:  400005e1 ffffffff ffffffff ffffffff
[13:18:49]3fffeb50:  4026ddcc 00000033 0000001e ffffffff
[13:18:49]3fffeb60:  40105822 04000102 00000000 00000001
[13:18:49]3fffeb70:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3fffeb80:  0000001a 00000018 04000102 40105804
[13:18:49]3fffeb90:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3fffeba0:  00000000 00000000 00000000 00000000
[13:18:49]3fffebb0:  00000000 00000000 00000000 00000000
[13:18:49]3fffebc0:  00000000 ffffffff ffffffff ffffffff
[13:18:49]3fffebd0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffebe0:  ffffffff 000001ff ffffff04 ffffff01
[13:18:49]3fffebf0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffec00:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffec10:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffec20:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffec30:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffec40:  4010581c 40105819 ffffffff ffffffff
[13:18:49]3fffec50:  400005e1 ffffffff ffffffff ffffffff
[13:18:49]3fffec60:  4026ddcc 00000033 0000001e ffffffff
[13:18:49]3fffec70:  40105822 04000102 00000000 00000001
[13:18:49]3fffec80:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3fffec90:  0000001a 00000018 04000102 40105804
[13:18:49]3fffeca0:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3fffecb0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffecc0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffecd0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffece0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffecf0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffed00:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffed10:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffed20:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffed30:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffed40:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffed50:  4010581c 40105819 ffffffff ffffffff
[13:18:49]3fffed60:  400005e1 ffffffff ffffffff ffffffff
[13:18:49]3fffed70:  4026ddcc 00000033 0000001e ffffffff
[13:18:49]3fffed80:  40105822 04000102 00000000 00000001
[13:18:49]3fffed90:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3fffeda0:  0000001a 00000018 04000102 40105804
[13:18:49]3fffedb0:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3fffedc0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffedd0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffede0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffedf0:  ffffffff 00000003 ffffffff ffffffff
[13:18:49]3fffee00:  4010440f 00040000 00000000 00040000
[13:18:49]3fffee10:  00000000 4010440c 00040000 ffff0064
[13:18:49]3fffee20:  3ffee640 4010336f ffffffff ffffffff
[13:18:49]3fffee30:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffee40:  ffffffff 2c9f0300 4000050c 3fffc278
[13:18:49]3fffee50:  401031c0 3fffc200 00000022 ffffffff
[13:18:49]3fffee60:  4010581c 40105819 0000001e ffffffff
[13:18:49]3fffee70:  400005e1 00000023 00000020 3fffdb10
[13:18:49]3fffee80:  4026ddcc 00000033 0000001e c0000000
[13:18:49]3fffee90:  40105822 04000102 00000000 00000001
[13:18:49]3fffeea0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3fffeeb0:  0000001a 00000018 04000102 40105804
[13:18:49]3fffeec0:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3fffeed0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffeee0:  ffffffff ffffffff ffffffff ffffffff
[13:18:49]3fffeef0:  00000608 000000c1 000000c1 401010df
[13:18:49]3fffef00:  0000003d 00000001 40105465 3ffef958
[13:18:49]3fffef10:  3fffdc10 00000000 00000020 40101363
[13:18:49]3fffef20:  4026f0d8 40101bdc 00000000 00000000
[13:18:49]3fffef30:  40101c11 00000000 3fff1f64 3ffe8830
[13:18:49]3fffef40:  00000000 3fffdad0 3fff0da0 402494d4
[13:18:49]3fffef50:  40000f49 3fffdab0 3fffdab0 40000f49
[13:18:49]3fffef60:  40000e19 00000005 000a9950 00000000
[13:18:49]3fffef70:  4010581c 40105819 000000ed 4010561d
[13:18:49]3fffef80:  400005e1 000a9950 00000000 00000000
[13:18:49]3fffef90:  4026ddcc 00000033 0000001e 00000100
[13:18:49]3fffefa0:  40105822 04000102 00000000 00000001
[13:18:49]3fffefb0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3fffefc0:  0000001a 00000018 04000102 40105804
[13:18:49]3fffefd0:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3fffefe0:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3fffeff0:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff000:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff010:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff020:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff030:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff040:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff050:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff060:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff070:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff080:  4010581c 40105819 feefeffe feefeffe
[13:18:49]3ffff090:  400005e1 feefeffe feefeffe feefeffe
[13:18:49]3ffff0a0:  4026ddcc 00000033 0000001e feefeffe
[13:18:49]3ffff0b0:  40105822 04000102 00000000 00000001
[13:18:49]3ffff0c0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3ffff0d0:  0000001a 00000018 04000102 40105804
[13:18:49]3ffff0e0:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3ffff0f0:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff100:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff110:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff120:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff130:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff140:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff150:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff160:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff170:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff180:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff190:  4010581c 40105819 feefeffe feefeffe
[13:18:49]3ffff1a0:  400005e1 feefeffe feefeffe feefeffe
[13:18:49]3ffff1b0:  4026ddcc 00000033 0000001e feefeffe
[13:18:49]3ffff1c0:  40105822 04000102 00000000 00000001
[13:18:49]3ffff1d0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3ffff1e0:  0000001a 00000018 04000102 40105804
[13:18:49]3ffff1f0:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3ffff200:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff210:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff220:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff230:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff240:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff250:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff260:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff270:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff280:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff290:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff2a0:  4010581c 40105819 feefeffe feefeffe
[13:18:49]3ffff2b0:  400005e1 feefeffe feefeffe feefeffe
[13:18:49]3ffff2c0:  4026ddcc 00000033 0000001e feefeffe
[13:18:49]3ffff2d0:  40105822 04000102 00000000 00000001
[13:18:49]3ffff2e0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3ffff2f0:  0000001a 00000018 04000102 40105804
[13:18:49]3ffff300:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3ffff310:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff320:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff330:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff340:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff350:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff360:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff370:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff380:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff390:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff3a0:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff3b0:  4010581c 40105819 feefeffe feefeffe
[13:18:49]3ffff3c0:  400005e1 feefeffe feefeffe feefeffe
[13:18:49]3ffff3d0:  4026ddcc 00000033 0000001e feefeffe
[13:18:49]3ffff3e0:  40105822 04000102 00000000 00000001
[13:18:49]3ffff3f0:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3ffff400:  0000001a 00000018 04000102 40105804
[13:18:49]3ffff410:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3ffff420:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff430:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff440:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff450:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff460:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff470:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff480:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff490:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff4a0:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff4b0:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff4c0:  4010581c 40105819 feefeffe feefeffe
[13:18:49]3ffff4d0:  400005e1 feefeffe feefeffe feefeffe
[13:18:49]3ffff4e0:  4026ddcc 00000033 0000001e feefeffe
[13:18:49]3ffff4f0:  40105822 04000102 00000000 00000001
[13:18:49]3ffff500:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3ffff510:  0000001a 00000018 04000102 40105804
[13:18:49]3ffff520:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3ffff530:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff540:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff550:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff560:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff570:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff580:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff590:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff5a0:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff5b0:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff5c0:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff5d0:  4010581c 40105819 feefeffe feefeffe
[13:18:49]3ffff5e0:  400005e1 feefeffe feefeffe feefeffe
[13:18:49]3ffff5f0:  4026ddcc 00000033 0000001e feefeffe
[13:18:49]3ffff600:  40105822 04000102 00000000 00000001
[13:18:49]3ffff610:  fbf8ffff 04000002 3feffe00 00000100
[13:18:49]3ffff620:  0000001a 00000018 04000102 40105804
[13:18:49]3ffff630:  3fffc100 3fff0938 00000000 00000000
[13:18:49]3ffff640:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff650:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff660:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff670:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff680:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff690:  feefeffe feefeffe feefeffe feefeffe
[13:18:49]3ffff6a0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff6b0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff6c0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff6d0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff6e0:  4010581c 40105819 feefeffe feefeffe
[13:18:50]3ffff6f0:  400005e1 feefeffe feefeffe feefeffe
[13:18:50]3ffff700:  4026ddcc 00000033 0000001e feefeffe
[13:18:50]3ffff710:  40105822 04000102 00000000 00000001
[13:18:50]3ffff720:  fbf8ffff 04000002 3feffe00 00000100
[13:18:50]3ffff730:  0000001a 00000018 04000102 40105804
[13:18:50]3ffff740:  3fffc100 3fff0938 00000000 00000000
[13:18:50]3ffff750:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff760:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff770:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff780:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff790:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff7a0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff7b0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff7c0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff7d0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff7e0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff7f0:  4010581c 40105819 feefeffe feefeffe
[13:18:50]3ffff800:  400005e1 feefeffe feefeffe feefeffe
[13:18:50]3ffff810:  4026ddcc 00000033 0000001e feefeffe
[13:18:50]3ffff820:  40105822 04000102 00000000 00000001
[13:18:50]3ffff830:  fbf8ffff 04000002 3feffe00 00000100
[13:18:50]3ffff840:  0000001a 00000018 04000102 40105804
[13:18:50]3ffff850:  3fffc100 3fff0938 00000000 00000000
[13:18:50]3ffff860:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff870:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff880:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff890:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff8a0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff8b0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff8c0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff8d0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff8e0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff8f0:  feefeffe feefeffe feefeffe feefeffe
[13:18:50]3ffff900:  4010581c 40105819 feefeffe feefeffe
[13:18:50]3ffff910:  400005e1 feefeffe feefeffe feefeffe
[13:18:50]3ffff920:  4026ddcc 00000033 0000001e feefeffe
[13:18:50]3ffff930:  40105822 04000102 00000000 00000001
[13:18:50]3ffff940:  fbf8ffff 04000002 3feffe00 00000100
[13:18:50]3ffff950:  0000001a 00000018 04000102 40105804
[13:18:50]3ffff960:  3fffc100 3fff0938 00000000 00000000
[13:18:50]3ffff970:  40004b31 3fff4874 00000040 000f7080
[13:18:50]3ffff980:  4010697c feefeffe feefeffe feefeffe
[13:18:50]3ffff990:  00000000 400042db 000f7080 000f70c0
[13:18:50]3ffff9a0:  40004b31 3fff4874 00000040 000f8180
[13:18:50]3ffff9b0:  4010697c feefeffe feefeffe 4024a48c
[13:18:50]3ffff9c0:  00000000 400042db 000f8180 000f81c0
[13:18:50]3ffff9d0:  40004b31 3fff4874 00000040 000f8540
[13:18:50]3ffff9e0:  4010697c 3fff4874 00000040 000f8500
[13:18:50]3ffff9f0:  40100965 3fff4874 000f8540 000f8580
[13:18:50]3ffffa00:  40100965 3fff4874 000f8540 4024757d
[13:18:50]3ffffa10:  4010581c 40105819 000f8500 4024a48c
[13:18:50]3ffffa20:  400005e1 400042db 00000040 000f8580
[13:18:50]3ffffa30:  4026ddcc 00000033 0000001e 000f8640
[13:18:50]3ffffa40:  40105822 04000102 00000000 00000001
[13:18:50]3ffffa50:  fbf8ffff 04000002 3feffe00 00000100
[13:18:50]3ffffa60:  0000001a 00000018 04000102 40105804
[13:18:50]3ffffa70:  3fffc100 3fff0938 00000000 00000000
[13:18:50]3ffffa80:  4010697c 3fff20b4 00001000 00000001
[13:18:50]3ffffa90:  00000000 400042db 000f8680 000f86c0
[13:18:50]3ffffaa0:  40004b31 3fff2324 00000040 000dc400
[13:18:50]3ffffab0:  4010697c 3fff20b4 00001000 4024a48c
[13:18:50]3ffffac0:  40100965 3fff2324 000dc400 000dc440
[13:18:50]3ffffad0:  3fff4874 00000001 000dc400 4024757d
[13:18:50]3ffffae0:  3fff204c 00000001 3fff4804 4024a48c
[13:18:50]3ffffaf0:  00000001 000001c8 000001c8 402022fc
[13:18:50]3ffffb00:  3fff2324 00000040 00000001 40201306
[13:18:50]3ffffb10:  00000063 3fff20b4 00001000 00000000
[13:18:50]3ffffb20:  4010581c 40105819 00000400 402397ee
[13:18:50]3ffffb30:  400005e1 00000001 00001000 40201306
[13:18:50]3ffffb40:  4026ddcc 00000033 0000001e 0000143f
[13:18:50]3ffffb50:  40105822 04000102 00000000 00000001
[13:18:50]3ffffb60:  fbf8ffff 04000002 3feffe00 00000100
[13:18:50]3ffffb70:  0000001a 00000018 04000102 40105804
[13:18:50]3ffffb80:  3fffc100 3fff0938 00000000 00000000
[13:18:50]3ffffb90:  00000001 000001c8 ffffffff ffffffff
[13:18:50]3ffffba0:  00000002 00000001 ca9d52d3 aff003cb
[13:18:50]3ffffbb0:  8010080c 00000400 aff003cb 00000000
[13:18:50]3ffffbc0:  00000004 3fff20b4 00000000 00000002
[13:18:50]3ffffbd0:  00000001 00000000 78000000 0000000b
[13:18:50]3ffffbe0:  ffffffff 00000000 00000004 500ffc34
[13:18:50]3ffffbf0:  3ffffc51 3fff4844 00000001 3fff204c
[13:18:50]3ffffc00:  0000000b 002ffc00 3ffe8e9f 40201dee
[13:18:50]3ffffc10:  40202784 3ffffc20 000005e0 401010df
[13:18:50]3ffffc20:  00000688 3ffe8e9f 0000000b 00000000
[13:18:50]3ffffc30:  4010581c 40105819 00000000 00000000
[13:18:50]3ffffc40:  400005e1 00000020 40269daf 00000001
[13:18:50]3ffffc50:  4026ddcc 00000033 0000001e 00000008
[13:18:50]3ffffc60:  40105822 04000102 00000000 00000001
[13:18:50]3ffffc70:  fbf8ffff 04000002 3feffe00 00000100
[13:18:50]3ffffc80:  0000001a 00000018 04000102 40105804
[13:18:50]3ffffc90:  3fffc100 3fff0938 00000000 00000000
[13:18:50]3ffffca0:  00000000 4025ce7b 3ffee89c 3fff1fa4
[13:18:50]3ffffcb0:  3ffea216 00000001 3fff0c38 4024a48c
[13:18:50]3ffffcc0:  3fff2fc5 3fff33fc 0000000f 3ffeefe0
[13:18:50]3ffffcd0:  3ffea216 3ffea216 3fff37f7 4025ecb3
[13:18:50]3ffffce0:  3ffeef94 4025e884 40260ee8 3ffeef94
[13:18:50]3ffffcf0:  40105f01 0000f43f 3ffef0c0 00000000
[13:18:50]3ffffd00:  3ffef7d0 3ffef0c0 00000000 4025dd4c
[13:18:50]3ffffd10:  00000000 000061c3 4026087b 3ffef088
[13:18:50]3ffffd20:  3ffef0c0 40260ee8 3ffeef94 40100c90
[13:18:50]3ffffd30:  3ffee920 402607f0 3ffee89c 00000012
[13:18:50]3ffffd40:  4010581c 40105819 3ffee920 00000012
[13:18:50]3ffffd50:  400005e1 3ffee89c 00000012 4027146e
[13:18:50]3ffffd60:  4026ddcc 00000033 0000001e 40260ee8
[13:18:50]3ffffd70:  40105822 04000102 00000000 00000001
[13:18:50]3ffffd80:  fbf8ffff 04000002 3feffe00 00000100
[13:18:50]3ffffd90:  0000001a 00000018 04000102 40105804
[13:18:50]3ffffda0:  3fffc100 3fff0938 00000000 00000000
[13:18:50]3ffffdb0:  3fff33fc 40235cc0 3ffe8736 3ffe8736
[13:18:50]3ffffdc0:  40235e9d 40235e79 3fff0acf 40235ea3
[13:18:50]3ffffdd0:  00000000 00000000 00000000 00000000
[13:18:50]3ffffde0:  00000000 00000000 00000000 00000000
[13:18:50]3ffffdf0:  00000000 00000000 00000000 00000000
[13:18:50]3ffffe00:  00000000 00000000 00000000 00000000
[13:18:50]3ffffe10:  00000000 00000000 00000000 00000000
[13:18:50]3ffffe20:  00000000 00000000 00000000 00000000
[13:18:50]3ffffe30:  ffffff00 00ffffff 3ffefdea 40234ff7
[13:18:50]3ffffe40:  20746547 2066664f 4c20794d 006e7761
[13:18:50]3ffffe50:  4010581c 40105819 00000019 401010df
[13:18:50]3ffffe60:  400005e1 746e6163 76616820 68742065
[13:18:50]3ffffe70:  40224501 00000030 0000001e 4010139a
[13:18:50]3ffffe80:  4022ea2d 00000001 2532c1bf 40267aed
[13:18:50]3ffffe90:  00000000 00000000 00000000 fffffffe
[13:18:50]3ffffea0:  000000b0 3fffc6fc 0000003d 3fff0888
[13:18:50]3ffffeb0:  00000000 3fff0938 3fff0da0 00000000
[13:18:50]3ffffec0:  00000001 00000000 00000001 3ffe8736
[13:18:50]3ffffed0:  402728f3 3fff0b4a 00000000 3ffefdea
[13:18:50]3ffffee0:  4022e578 00000000 3fff0b4a 4022e568
[13:18:50]3ffffef0:  00000000 4bc6a7f0 1a9fbe76 00000000
[13:18:50]3fffff00:  007a1200 2532c32d 4bc6a700 00000000
[13:18:50]3fffff10:  00000000 00000000 00000001 40100914
[13:18:50]3fffff20:  00000000 00000000 00000000 3fff0da0
[13:18:50]3fffff30:  3fffdad0 3fff0c54 00000000 40249596
[13:18:50]3fffff40:  4024a9f8 00000000 00000450 402495d0
[13:18:50]3fffff50:  3ffffeb0 3fff0c54 3fff0b18 402479d1
[13:18:50]3fffff60:  3fffdad0 3ffe8715 3fff0b18 3fff0da0
[13:18:50]3fffff70:  3fffdad0 00000000 3ffefdea 4022ea2d
[13:18:50]3fffff80:  feefeffe 00efeffe feefeffe 3fff0da0
[13:18:50]3fffff90:  3fffdad0 00000000 3fff0d60 4022f598
[13:18:50]3fffffa0:  feefeffe feefeffe feefeffe 40249678
[13:18:50]<<<stack<<<
[13:18:50]
[13:18:50]--------------- CUT HERE FOR EXCEPTION DECODER ---------------
That behavior telling you that your controller is in a loop. Maybe you flashed wrong firmware or you have a weak power supply and brownout detector rebooting your controller.
I managed to work this out. Well… I’m still not certain what caused the initial problem, but after trying two of my D1 Mini clones, I switched to a different ESP board I had here, and that one works flawlessly. I am not sure if my D1 Minis are just junk, or if I was doing something wrong, but the other board has been working great for a week now. shrug
use a 1000 uf capacitor in 3.3 v and gnd of wemos 1. after burning the firmware it takes it out…
It happens to me with some wemos
Cheers…
I use google translate…
