Does the wireless AP WLED-xxxx show up in your list of available wireless networks? If it does, you need to join that long enough to change the 2.4GHz wifi connection parameters (SSID / PWD). Also, it helps if you are also connected to the same 2.4GHz wifi (in case you are using a portable device like smartphone or tablet) - sometimes just switching to the 2.4GHz wifi on the portable device solves it for some people once they get the WLED wifi setup.
huggy-d1
8
Related topics
| Topic | Replies | Views | Activity | |
| Cannot install on 2 different ESP32 devices | 16 | 1531 | December 29, 2023 | |
| WT32-ETH01 - does it work | 4 | 3243 | December 29, 2021 | |
| Cannot get WLED flashed on ESP32-Mini-1 | 11 | 680 | December 4, 2024 | |
| WT32-ETH01 hangs on boot after PSU power up | 25 | 10723 | October 2, 2024 | |
| wESP32 revision 7 ETH_PHY_RTL8201 support | 6 | 1361 | March 19, 2025 |
