Xiao ESP32C3 board not installing WLED. even if flashed successfully sometimes, it doesn't show up on Wi-Fi
Trying out Xiao ESP32C3 board and its not installing WLED. even if flashed successfully sometimes, it doesn’t show up on Wi-Fi.
Tried all possible methods. The previous posts i saw are a year or even older. Does anyone have same issue in 2023 ? Kindly guide me.
This example worked for both Lolin c3 mini for me and seeed Xiao C3 for others , Discord
Which example?
That was old news and link is there in wled discord , but now you are in luck as the new update for C3 works directly from the installer ,
Try from WLED installation (wled-install.github.io)
or from here WLED installation (wled-install.github.io)
