Hello.
I am very new to programming field. Have 0 knowledge. Bought this MCU for a macropad and realized it doesn’t have USB HID.
Then I came to know about WLED. But when I try to install it gives me error that ESP32C3 is not supported.
Is there any tutorial/ step by step guide to make it work?
I like this project and looking to put this MCU for good use than throwing in a bin.
The link is not working. I have a Seedstudio Xiao ESP32-C3, i´m having issues trying to install WLED on it.
Yes, that’s old. Try here.
I was able to correct that behaviour by pushing the “BOOT” button as I was plugging in the board to the computer. I was then able to flash the XIAO ESP32C3 without any error. WLED is now running on it.
Thank you and hope it helps other too
Perfect! Thanks so much.
Hey
I flashed my XIAO ESP32C3 but I cant connect to it because the access point doesn’t show up in my wifi settings. Am I doing something wrong?
Most likely.
C3 needs its own binary, bootloader and partition table.
Easiest approach is compiling and uploading using MS VSC + PIO.
Yeah , the way it worked is using below
esptool.exe -p COM10 erase_flash
esptool.exe -p COM10 write_flash 0x0 C3_bootloader.bin
esptool.exe -p COM10 write_flash 0x8000 C3_partitions.bin
esptool.exe -p COM10 write_flash 0x010000 6_may_lolin_c3_mini_T2.bin
The bins we tested with ,bootloader and partitions are linked here Discord .
Hi guys, after reading a lot of threads online, installing VScod with PlatformIO (build fails btw)
I have found that the best (simple) approach is to go WLED installation https://wled-install.github.io/
There you select the ESP32-C3 (4MB Flash, Lolin WiFiFix for some C3 mini V1.0.0)
And then Install it, that is all, works like a charm ![]()
Yes that is a new change introduced only one week ago , it simplify flashing as it was a headache
