Hey what type of strip should i set it to as i am using analogs im not sure how to program it. im pretty sure i got my wiring right but i also know the software isnt correct. so i need some help at least with getting that started
The analog strip types are the “PWM xxx” variations under Config->LED Preferences>LED Outputs.
They give you 1 virtual led attached to the GPIO pin(s) you choose.
In the case of RBGW type analog (for eg.) you need to assign 4 GPIO’s to drive each channel.
You may need a MOSFET driver for high current LED’s.
i have the mossfet in there already (rn im just trying to do 1 channel just for testing before i solder it all cause my breadboard is to small) in actualy running a 24v strip but got a mossfet to step up that high. i will give it a quick try
