Are presets supposed to work with UDP Sync?
This is my first time trying to use UDP Sync, I have 6 controllers (a mix of wifi and ethernet) on the latest 14.0 beta build. I set them all to the same Sync group and turned on the Sync button from my “main” controller. When I change effects or colors all of the controllers change as expected, my issue comes when I select a preset on the main controller nothing else changes.
If I set the UDP packet resend to 2 or 3 sometimes I can get the remote controllers to change with a preset selection one time but then never again, picking an effect changes all of the controllers again without a problem.
The documentation isn’t real clear on if I should be expecting this to work or not, I would assume it should pass the effect and color changes on but maybe my assumptions are wrong.
presets do not sync.
effects and their settings do
Right I’m not expecting the presets to copy over however if I select a preset on the main controller I should expect the colors and effects to be selected on the synced controllers?
If so that’s not happening for me. Works fine if I pick an effect or color on my own which is what I don’t understand
check if you have correct settings enabled
I’m not sure what else I can do differently
Here’s a video example of the behavior I’m getting. Picking effects/colors works 100% of the time to sync to other controllers. Picking a preset only changes the main controller but picking an effect afterwards changes them all again. This makes me think there’s a bug of some kind where it’s not transmitting the effect/color when a preset is selected vs a setup issue.
WLED Sync - YouTube
I am seeing something similar with 0.13.2, but with playlist, not selecting presets.
selecting presets works correctly.
are you using 0.14 or earlier version?
@SK360 Unless I’m missing something, UDP syncing preset JSON info of the sender works like a champ for me with v0.13.1. I use it for the sound reactive architecture described here.
Hope this helps!
Gbd
14.0 build 2211300 on everything.
Noticing some more interesting behavior, if I enable just my WiFi controllers to be in a sync group syncing effects and colors from a preset seems to work just fine. However my ethernet controllers will sync effects picked manually, colors picked manually but not presets.
Here is a video of my Wifi controllers syncing… Presets seem to apply correctly about 75% of the time
Wifi Controllers - YouTube
Here is my ethernet controllers, as you can see picking effects works fine across both however picking a preset worked the first time but then never again. Effects works 100% of the time though.
Ethernet Controllers - YouTube
I really don’t know how to make sense of it, I find it hard to blame a networking issue when effects and colors sync 100% of the time on ethernet or wifi and it’s just the preset recall that breaks on ethernet
I can confirm a bug in UDP sync.
The fix will be available shortly.
Thank you! I see the commit, will rebuild tomorrow and test again
I can confirm on 2212050 everything is working as expected now! Thank you for looking into it!
