Athom 15W bulb - OTA update
Hi all,
I think I flashed a wrong version last time because when I want to OTA update my bulb I get:
Not implemented
OTA updates are disabled in this build.
I know that all Athom bulb have 2MB memory, did I flash the 1MB? Is there a way to flash the latest version of WLED? Now it is stuck on 0.13.0-b6 (build 2112080)
You then need to serially flash it with a 2M bin.
No other option then open it up? I’m not sure if the pins are available.
No and they are. I screwed up and had to do it once. :smiley:
Ooh, Just got to my lamp and this is the 7w version. Do you have a pin layout? Can’t find it.
Also the pin that are available are very small.
It’s on their site. Yes, it’s a pain. Don’t do that again! :smiley:
Then you sire are Sherlock Holmes! I searched this afternoon and now for an hour!
Any directions or link?
Their site seems broken right now. :frowning: I can’t pull up any products.
What site do you mean? https://www.athom.tech/ is working for me.
Started working, but I guess they moved it? I found something here.
I found that post to, but does it make sense to you what the pinout is?
They are talking about desoldering.
Did you use these pins? I wanted to solder small wires to these pins. But what is what?
That’s a connector and you just unplug the LED board (pull out). See pic.
Finally made time to solder. I managed to solder the wires just like you did. But what is the pin out? Is this an esp-12? It looks like an esp-04 but it has 8 pads instead of 7
For flashing, you use just 3.3v, rxd, txd, gpio0, and gnd.
Sure ofcourse, but what is what?
