Audio Sync Not Consistent Across Multiple Lights
Hi I have 6 separate light strips, each with their own esp32. These all run on my home wifi network.
I have 1 act as the master with a digital microphone for audio effects.
All esp32 have wled 14 with audio usermod downloaded. I have the master set to send and the 5 slaves set to receive.
When I play music, they do sync up and it is pretty decent, but the timing can be off. Probably less than 1 second for a rough order of magnitude. When they are not in perfect sync it kind ruins the effect.
Is there anyway to adjust timing?
Each strip is (120) ws2812 about 6’ in length.
