I have a dig-uno, and am looking at BTF part number RGBWW5M505060LW65, but I can’t tell how to wire it (there is no ground pin, for one) and how to set WLED up.
The pin order is 12V+, G, R, W, B
I realize I can probably only control white and one other color, which is fine for now, maybe I’ll get another controller board later. But what would I select for the LED output dropdown since it’s not WS281x or something common? They’re supposedly addressable.
And as for wiring, do I just plug one color into one channel, another into the other, and ignore ground? How would I do power injection?
Those are not addressable strips. Those are RGBW analog (dumb) strips. You would need other hardware to control those with an addressable LED controller. Quindor does also sell controllers for analog LEDs. Analog LED dimming - quinled.info
For info to control them with WLED: Compatible LED strips - WLED Project
If they were addressable they would have + data - not + R (red) G (green) B (blue) W (white)
