Hey so i use the sunrise function a lot and i’ve recently redone the bedroom led strip.
Issue i’m having is that my MQTT alarm sends an api call &ND
which won’t do anything if home assistant has turned the main led strip segment off.
Would it be possible to add a checkbox to turn the main segment on when using the timer function?
Thanks!
