I’d like to WLED a whole room. Bottom and Top
PSU is outside of the room. The way to the first stripe 2.5m (from ceiling to the bottom / respectively the other way around)
Please find the graphic attached. (This shows only one part (ceiling for example)
Green = LEDs
yellow = distances
blue = diameter
PSU 5V / 60 AMP
Is the voltage drop really that critical? Do you know if it is still that critical if I reduce to 90% brigthness?
How to solder these thick wires? Or can I use some Wagos and reduce diameter on the last inch?
The blue circles are my power input points. Do I have to sum the LEDs if I input in both directions?
Did I use the calculator correctly in this scenario?
Best regards and thank you!
