I was playing with displaying football team colors and did the colors for the Vikings
I then tried the 2 colors for the Green Bay Packers however the yellow/gold works but the dark green does not
Here is the 2 color codes
dark green: 203731 (no light emitted)
yellow/gold: FFB612 (works fine)
Any chance you’ve got the Automatic Brightness Limiter enabled or the total and/or segment brightness set low?
That colour doesn’t have much brightness set for any of the R,G, or B elements and if you were then to limit its overall brightness somehow you might not get any output.
The test string I tried definitely gave colour with 203731 for RGB.
Thanks for trying that!! I did have automatic brightness limiter on, but even after turning it off it was still completely dark. I slid the brightness slider over all the way…but still no. …so weird
