Yesterday while firing up a strip for the first time from the default WLED settings, I set it up to sync with a running WLED instance which is running 3 colors with something like a tri-color chase.
The key is the existing WLED displays 3 colors and was sending out sync updates for use by the new WLED instance.
Once they were syncing, what would you expect if the correct strip color were RGB but GRB (default) was selected? 3 colors, but the wrong 3 colors, right?
I saw 2 colors.
Adjusted strip order to RGB and 3 colors magically appeared on the new strip.
The original WLED instance’s 3 colors: ~RED, ~BLUE, ~GOLD
Imagine that sent to the strip as GRB instead of RGB. Should still be 3 unique but wrong colors, correct? It was all very odd to see. A real head-scratcher for me. I didn’t waste too much time getting the new instance going while scratching my head, but when I woke up today I knew I had to ask to “pixel-heads” amongst us…
Probably a visual anomaly.
