I am trying to get an SK6812 RGBW 12V strip setup, and am running into the colors not showing up correctly. I was told by the manufacturer that I should set the color order to RGB, but that does not result in the correct colors. If I set it to BRG, I get the correct colors for red, and green. For the Blue though, the color is the warm white. If I move the color slider all the way down and the white slider all the way up, I think get a blue color.
I have seen mention of a checkbox in the setting to indicate 4-channel LEDs (RGBW). There is no place for me to check that checkbox, but I am assuming because I am picking SK6812 RGBW in the drop down, it knows that I am using RGBW.
Any tips on correcting this problem?
