Arn
1
I used this settings and i can control the 2814 RGBW Stripes with wled:
SK6812 RGBW
Color Order: BRG
Swap: w - g
White is not working.
Only three led can be controled at a time. So when green and white are switched - the white Led in RGBW cannot be addressed anymore.
Any idea how to fix that?
Arn
2
Ok i found the solution here:
You have to set:
Auto-calculate white channel from RGB:
“Accurate”
Whatever this means it works.
kilrah
3
Or set the white level yourself from the white slider.
Arn
4
Did not see that slider bevore.
Yes also works but it is not so smooth to set.
