I made LED boards with 3 different LEDs: 1800K, 2700K and 5700K
Why?
I did this because I wanted the extra-warm-white but my tests showed that mixing 1800K and 5700K does not give a nice standard warm white. Theory proved that this is not caused by the selection of the LEDs, but this is a general problem: In the CIE color space white is on a curve, that gets a lot more “curved” for low white temperatures. When mixing two different whites the resulting color is on a straight line between these two whites, but for low color temperatures the line approximation is not good.
I would like to make these controllable with an ESP (the LED drivers for each channel have PWM input). Is WLED suited for this (there is no RGB stuff). What is needed to add support for these concept? Is it something that could be added easily, basically just adding an output channel somewhere and adjusting the temperature/intesity calculation, or would I basically have to rewrite everything, because CCT is considered everywhere to have two channels?
Best regards
Stefan
