Hi, i am overwhelmed in adding a single strip to a matrix. My setup is like this:
I have added a single strip with 224 LEDs over DDP - but i never get a 1D strip on the segment:
( accordeing to the doc i expected to enter something outside the 54x80 matrix, but that didn’t work)
to add a trailing strip, you add it AFTER the matrix, which means after pixel 4320
Got it, Thanks. The solution was to enter 4320 in the startx field. New problem:
but i can’t save it, clicking this hook has no effect at all (using 15.4 beta)
not sure why, you may be hitting RAM limitations or a bug. try the same but with a smaller 2D setup.
