For the pool, I have a flatLED 7.8 with 12 RGBW LED. It’s currently controlled from an eldoLED POWERdrive with RF controller which allows me to select a few solid solid colours only. I figure there must be a better way.
The LED controller has a DMX control so I was thinking that could be a start. I’m looking to use WLED and only WLED to control the pool LED; I’m not looking to use any other interface since WLED integrates so nicely with my home automation system over MQTT. It would make for some nice pool lighting automation ![]()
On the WLED DMX output wiki, I found a reference to Robert Oostenveld’s hardware setup with a MAX485 to the WLED TX-pin. I’m looking to use an ESP8266 as the controller.
I have a few questions on this approach that I hope you as a collective can help with:
- Is this approach feasible? Can I control a DMX light with WLED only? Would the multiple LEDs be individually addressable as if they were on a strip (with all of the effects that then allows)?
- Reference to the TX-pin: is that the WLED defined GPIO (default 2) or is another meant?
- Is it just a case of wiring up as per Robert’s example and done? Or what else is needed in addition to (instead of) the MAX485?
Thanks for your thoughts and suggestions on this subject!
