I’ve upgraded to WLED 13b5 and under the sync interfaces I can only select E1.31 or Art-Net. Under WLED 12 I was able to select DDP. Does anybody know why that has changed?
DDP is sh*t!
Erm, no it is not. It is awesome and it is now always enabled!
Perfect, thank you!
What does always enabled mean ?
What would I set in the drop down menu ? E.131, Artnet, Custom port ?
Exactly that: “ALWAYS ENABLED”
You cannot disable it. Not even by custom compiling unless you remove DDP handling code from WLED.
So I don’t have to any settings in Sync interfaces ?
No, you don’t.
Thank you !
In WLED 13b5, it seems that the DDP (Dynamic Data Protocol) option might have been removed or is temporarily unavailable in the sync interfaces section. This can happen during updates when certain features are being refactored or improved.
Here are a few things you can try:
Check Release Notes: Look at the release notes or change logs for WLED 13b5. They may provide information on any removed or changed features.
Configuration Settings: Double-check the configuration settings after the upgrade. Sometimes, settings reset, and you might need to re-enable certain protocols.
Community Forums: Visit the WLED community forums or GitHub issues page. Other users may have encountered similar issues, and there might be a workaround or explanation.
Rollback: If DDP is critical for your setup, consider rolling back to WLED 12 until DDP support is restored in a future version.
Feedback to Developers: If you think DDP should be included or if you have specific use cases for it, consider providing feedback to the developers on their GitHub page.
If you find any updates or if others in the community have more information, it could clarify the situation!
