not sure if somebody already asked the question, but I have a problem to connect a 3x2,5mm2 cable on a LED strip, are there any possible connectors which you can recommend? The LED strip is built into an aluminium profile.
Thanks for your quick reply. The problem is the additional connection which I would have which would no longer be reachable after the installation. Do you know any preconfigured connectors which will be used. Don’t I get problems with the heat of the cables?
I don’t know any connecers. Wago maybe?
if you dimensioned your cables right, they are nowhere near the temperature limit. going to a smaller cable for a short run is not a problem. https://www.powerstream.com/Wire_Size.htm gives you limits for chassis wiring. 2.5mm^2 can handle 35A for example.
