anybody here compiled a customed binary with specific amount of pixels per output? (not default 300 as Quindor created). I’ve never done it before, can somebody walk me through?
From what I’ve seen, i don’t think you need to change code to get it to work with whatever setup you have as long as each output uses no more than 300 LEDs.
I use less than 300 per channel and in order to achieve continous effect across all 4 outputs I need to set exact amount of pixels.Otherwise there’s delay (not continous) as effect travels across channels.
