Dig-Uno and WLED sequencal prop control
I have a few of these Dig-uno w/wled to potentially control my Christmas show
I have four snow flakes, 48 pixels each, total of 192, each are set up to follow from beginning:
beginning flake, second flake following beginning and so on. This is how its set up in xlights visualizer.
My question, it plays as one long string, cant control each flake individually, is this a limitation of dig-uno or wled?
I know it works with my 4 port long range falcon, just diddnt want to burn a 4 port module for a single chain prop.
They, dig-uno wled, work great controlling a single prop
thanks
You are trying to control them individually in xlights or with WLED?
If xlights:
Did you create a separate model for each flake? If not, you need to. If yes, just drag them onto whatever controller port you have them connected to In the order they are wired See Pic:
If you want to control them individually in WLED you need to create a segment for each one and adjust the colors/fx for whatever segment (flake) you choose.
Hi Jinx
thx, boy do I feel like the loose nut in the seat, when I saw your reply, I recall setting up cat eyes from Boscoyo last night and they all worked great individually in Xlights with another dig-uno wled. On the flakes I just drew a blank, I had it the same as you do in above in xlights, my issues was they were all doing the same effect and same color, so it appeared they were not working individually, I thought I changed the color on each, but that dam loose nut in the seat…
thanks, getting ready for my first Christmas and about 40 props, I guess you overlook the simple stuff
thanks for getting me back on track
les
