Using Dual Channel on Dig-Uno
Will the QuinLED-Dig-Uno w Dual Channel play two different playlists “simultaneously” on two separate LED strips?
No, but this is not limited to Dig-Uno.
WLED cannot play 2 playlists at the same time.
Still, I think you interpreted the “playlist” wrong. Most likely you meant “different effect on each strip”. The answer to this is yes, you can set up each strip as a segment and have it controlled separately.
Yes, you are correct. Thanks for your precise answer.
WLED is very user-friendly, but it requires more than 3200 LEDs for illuminated signs. I haven’t been able to get Xlight to read my SP controller. What software would be a good option for having different channels and effects without being too complicated? It’s only for LED strips, not for making displays. Thanks.
