Hi all,
I haven’t got round to testing the new beta release of WLED 0.13b2.
Regarding playlists - I was wondering if it’s going to be possible to run seperate playlists across 2 or more output channels. In other words several playlist programs are running different effects on different pinouts?
If you have something external to WLED like xLights, control can be done in the way you suggest.
However, my understanding is each WLED has a single running playlist. If your playlists are time-synchronized in some way, you can set the the single running playlist to act on each strip as required.
I hope that makes sense. It’s basically creating 2 time diagrams (playlists over time), and then combine them into a single time diagram (playlist).
