I have an idea.
Is it possible to let wled read playlists within a playlists.
As nested loops can be made with repeating functions… Just deployed within main playlists.
This would aid playing collections of pixel art or wled presets on different panels.
Without repeating playlists sequences.
Your thoughts please…
No, nesting playlists is not (and may never become) possible.
But you can select a playlist as an end preset, so you can “chain” playlists.
Hi. Totally forgot to reply.
Sorry
I had a particular thing i needed to achieve. And sensibility would use a “nested” loop in properly. Just like the general use of repeating the playlust x amount of times a nested loop would have its exit point using that type of parameter.
But thanks for the reply although it seemed i was being scolded for suggesting such an “outrageous” request.
I do not know what scolded means but it was just a technical reply.
If you can figure out a way how to nest playlists you are welcome to submit a PR on Github.
