Dim strip in middle of run. Running two separate 15 meter runs (three 5 meter strips)ws2811 off dig quad, one run is dimmer in the center strip the other is beginning and end strip.I’ve tried injecting power and a different light strip. Is there a setting in WLED that addresses this. I’ve also tested volts. I’m at 12 volts at the end of my second strip. Injecting more power did nothing to change the brightness. Please tell me there’s a setting in WLED I’m missing
There is no setting that would make some LEDs dimmer that the other unless you are running multiple segments that aligned with that.
Qundor responded on Reddit, turns out I had to turn off the power limiter. Now they are all the same
