Using standard cable trunking as a poor man’s DIY alternative to professional aluminum channels.
Check this YouTube vid out:
Note that not all cable trunking “brands” are created equal – some transmit and diffuse light better than others.
You can not really tell without video but results looks good , I have used similar cable trunking and it is okay ( there are also somewhat cheap plastic led channels but not having good defuser or that will add to cost ) . I think if heat is not an a concern then plastic would do . I have a 30 M wall mounted 220v strips in plastic channels for around 2 years and it is still okay
“You can not really tell without video but results looks good” … YouTube video link ain’t working?
It working yeah , looks good
