For my project I plan on installing LED strips in Aluminum Channels on the eaves of my house. Since this is outdoors, I figured I should be using the IP67 strips.
However, I now see that the IP67 strips do not have the adhesive tape to stick into the aluminum channels. Why is this? Do the IP67 strips not need cooling? How should they be mounted?
Alternatively, I’ve read in some places that using the Aluminum Channels make it ok to use the IP65 strips outside (but I’ve also read places that disagree). Is there any consensus to this?
Thanks.
