Hello, I am currently using wled with nodemcu, but the ram is insufficient.
I’m doing research for this.
Does wled work with rasberry pie?
If it works, which Rasberry Pie models are compatible?
I will use it with a total of 2400 LEDs. Which cards can I use for this?
Thank you.
Raspberry can work as a FFP Player annd send data to the Node MCU
you also can make a Python that send the API commands like a LARGE Screen
see things like 16x16 ARTFX this is most sent to the MCU via CURL Command from Raspery PI
You cannot run WLED on the Pi, no.
