Hi guys,
I upgraded my bulb using the minimal uploader as it only has 1M of Flash. This went fine and i loaded the 1M (wled file WLED_0.12.0_ESP8266_1M.bin) via the UI. Also went fine and WLED loads however when i try to do anything i get the error:
Error 10: could not mount filesystem
Followed by:
SyntaxError: UnexpectedToken in JSON at position <0
I am able to set the WIFI and connect via AP or my wifi, but any power off or reboot, sets everything back to default. I tried doing a “Factory reset” but comes back with the same errors.
Is there a way i can reflash the bulb OTA, e.g. load the “minimum uploader” again via Arduino IDE and then reflash wled? Currently it doesnt show as a port in the IDE so not sure on any next steps.
James
