I’m trying to flash a bunch of magic home controllers with wled.
firmware was compiled with esp8285_4CH_MagicHome env and extended with this flags to save memory:
build_flags = ${common.build_flags_esp8266} -D WLED_DISABLE_HUESYNC -D WLED_DISABLE_ALEXA -D WLED_DISABLE_INFRARED -D WLED_DISABLE_BLYNK -D WLED_DISABLE_CRONIXIE -D WLED_USE_ANALOG_LEDS
flash is successful and the first connect to the wled-AP works.
But:
on the first page I get following warning/error:
SyntaxError:
Unexpected token < in JSON ap position0
and directly after that, on each buttonpress the following message:
Error 10: Could not mount filesystem!
Saving settings and/or presets are also not possible
What works: controlling (on, off, color, 1D effects)
have someone any idea? (i know, memory is to small, just 1m)
nice Forum.
Is it possible to flash from tasmota to WLED ota? Or do I have to open that tiny box again?
I tryed this things:
“Downgrade” to tasmota mini image.
Then tryed to flash WLED_0.11.0_ESP8266_1M.bin and WLED_0.11.0_ESP8266.bin thru ota (tasmota integrated webpage)
There is possibility that from Tasmota to WLED but Tasmota have to be version before they start check on firmware. As I recall prior to version 7. And to have ability to do OTA in the future use WLED_0.11.0_ESP8266_1M_OTA.bin
