Does this chip work with WLED??
Which one?
The TYWE3S chip
TYWE3S should be an ESP8266 so I would think yes.
It keeps coming up with WLED error 2
And which binary should
I be running on it?
Error 2 means it can’t write to flash, so you are using the wrong flash size. Looks like it’s 2M.
Which one should I be using?
Try this one:
WLED_0.x.x_ESP8266_1M_full.bin
Better yet, compile one yourself, I know it can be a little daunting at first but this gives you total control over how the pins get configured and what modules are included.
Is that board using GPIO2 for LED data?
To be honest I don’t have a clue
Oh my, @codyham put some heat shrink on those long exposed wires soldered onto that board. They appear to be touching in the center right of the posted image.
Sorry them wires have been taken off since the photo was only there to flash the chip
Is there a way to find out what pin the data for leds are
You are using a board that has no documentation? You’ll have follow the board traces between the LEDs and the micro.
Yeah it’s a board from
Bunnings!
That’s an analog strip kit. May be a clue in that Tasmota template, but I wouldn’t know for sure.
Yeah thought that could help some how
There’s also a esphome one aswell
Note that you would need an analog build of wled, not the one linked above.
Here is a link to the board with some more info about it.
TYWE3S - Tasmota
