H4NNE5
October 25, 2021, 10:10pm
1
I wanted to add a Debounce library to my project. After successful installation via PIO’s library interface and the include in the usermod.cpp
#include <ezButton.h>
the Build process failed
So I looked up where the extra libraries are installed and it’s inside this path “WLED-master.pio\libdeps\d1_mini\ezButton” in my case.
ezButton also appears several times int the platformio.ini
[env:d1_mini]
board = d1_mini
platform = ${common.platform_wled_default}
platform_packages = ${common.platform_packages}
upload_speed = 921600
board_build.ldscript = ${common.ldscript_4m1m}
build_flags = ${common.build_flags_esp8266}
lib_deps =
${esp8266.lib_deps}
arduinogetstarted/ezButton@^1.0.3
monitor_filters = esp8266_exception_decoder
So can anyone point out to me what I do have to change/add to get the libraries to be found?
Thanks in advance!
H4NNE5
tonyno
October 25, 2021, 11:52pm
2
Buttons are already debounced.
H4NNE5
October 26, 2021, 7:48am
3
That’s good to know, but doesn’t address the general question about why the new library isn’t known to the compiler.
H4NNE5:
You included like this:
or like this:
#include "ezButton.h"?
It should be like first one, but compiler says you did with double quotes, if I’m not wrong.
H4NNE5
October 27, 2021, 3:19pm
5
Yes, during posting, I mixed it up.
I tried it first with <> and after with “”, which both don’t work.
Then i’m not sure what’s wrong. You could put library files directly to wled00 folder and then include .h file with quotes in usermod.cpp, it should work.
H4NNE5
October 28, 2021, 9:13pm
8
That was also what I thought, but I want to understand how to make the project to recognize these additional libraries
H4NNE5
October 28, 2021, 9:16pm
9
Hey Huggy,
I don’t really understand what you want to point out. What do you mean with “easy path”? I already use PIO.
Mikolaj
October 29, 2021, 6:33am
10
What “bending to my will” are you talking about? No one talked about arduino IDE.
H4NNE5
November 1, 2021, 9:05pm
12
huggy-d1:
on how to add libraries in case that helps
Sorry that I’m annoyed, but I already mentioned this in my initial post:
The library is installed in this folder: \\WLED-master.pio\libdeps\d1_mini\ezButton\src , but the compiler apparently doesn’t know its existence.
Hopefully you are no longer annoyed I missed that juicy nugget.
Same here. I used ezButton in other projects with platform.io successfully. But WLED will not work. Did you solved the problem?
Greets
H4NNE5
November 20, 2021, 12:47pm
15
Hi, no not yet, I didn’t have time yet, to dig into the problem. Also I got no luck asking the members on Discord
