Hello guys, I need some help figuring out an issue with a project I recently did.
i will keep it short. I made 10 pillar lamps, I have cut out 10 chunks of 3leds out of a WS2812 strip.
I soldered wires at the bottom and at the top, tested them all individually with a gledopto controller, they all work as desired.
glued them in to the aluminum laps I made, installed them on the wlls, installed a 120 W power supply, everything workd up to the 8th set, 9 and 10 do not work. Tried everything.
Checked the cable integrity, checked the two sets individually again on the bench, played with setttings in Gledopto swapped the two around… I have 13V at each of the two spots, the continuity of the data conductor is good.
Any ideas help would be greatly appreciated.
Thank you.
