hi
specs
12v psu 200W
an 12/24>5v converter
warmwite DC12V WS2811
and a ESP8266 ESP-D1 MINI TYPE-C
latest firmwere on the esp! leds i hope they are paireble with esp? esp
to the problem, first cant find right data pin seams to be diffrent on 2 identical esp from same batch! tryed multipl pin!
and the leds lit up just cant controll them in wles. they have common ground on dc! scratching my head here! hope someone can help me
This is a quote from another topic dealing with W/W COB strips, They likely operate the same way as your single white strips where you need to see what color controls your LEDs brightness. Either R G or B.
Give this a try:
In: Config, User Interfaces. Check the box for RGB Sliders. Save and you should now have RGB sliders on your pallets.
Slide all 3 R, G, B sliders to the left.
Slide each, one at a time to the right till your lights light up. When they light, That slider is the one that your lights are tied to. See if using just that slider gets them working correctly.
this is really annoying!
got a new led strip LED
and still it dont work
i read this just now (Runs under WLED from 14b3 Settings for WS2814 RGBW Stripes are: SK6812 RGBW Color Order: BRG Swap: w - g)
what does he meen with bgr swap:w - g) “found it”
do you mean 12>5v? i got 12v powersupply and a 12/24>5volt and shared ground. updated firmwere in the mini D to latest. swapped w-g still no correct light… my knollege is ending here
