Govee H6056 in WLED
I just picked up a Govee H6056 and had to hack all the plastic bits apart to get it to work with WLED. Putting some info here so the next person doesn’t have to. The USB-C cable has 8 wires in it, labeled below.
Red: 12V
Black: Ground
White: RGB on Light 1
Green: CW on Light 1
Yellow: WW on Light 1
Purple: RGB on Light 2
Green: CW on Light 2
Grey: WW on Light 2
I have the RGB’s hooked up now, and have a Dig2analog coming in the mail to hook up the CW and WW’s. Will update this post if I remember when that comes in.
Hi, any new info?
how did you hock the rgb up? also did your Dig2analog arrive and did you get it working?
Wireing of the Dig2analog would also be nice. How exactly did you want to connect CW and WW to it since i only see RGBW on that device: https://quinled.info/wp-content/uploads/2023/11/QuinLED-Dig-Quad_dig2analog.png
I ordered it but didn’t end up using it. The warm white looked good enough and was bright enough to just use rgb. But it’s working great so far.
