Govee Strip Light 2 Pro (H61FX) and WLED
Good evening everyone. Pardon the X in the part number but the X represents the length of the kit you buy from Govee. The part I have is this one.
I am attempting to connect these strip LEDs to an ESP32 board with and without a level shifter. What I have found it that they will in fact light up and power up in different sections of color. It reacts when I change brightness and color but it is almost strobe like when I make any changes to either. Also, I can never get any one of the segments to be the actual color I select. It purples, and light reds and all different white temperatures but nothing is ever consistent. I have tried pretty much every LED profile in WLED 1.15 with and without a level shifter installed and I am either missing something really basic or these lights just are not compatible with WLED. Hoping someone can either point me in the right direction or just slam the door and I have to quit tilting at windmills.
Are you using the latest version with the tunable white (CCT) options? There should be three options, though only two are listed on the supported LED page. I have SM16925, WS2805 and FW1906.
Good Morning UMJohnny.
I am running WLED 1.15 and literally tried every LED profile. I just kind of gave up and am purchased a different type of strip because I really really want to use WLED to integrate WLED into my Control4 system. I don’t know enough about the protocol and chips on the strips. No one on here seems to have seen them or seen them work (judging from the responses or lack thereof) because you are the only one to respond. It could just be me as well. They seem to be a really popular strip light so I would assume this would have come up by now. Maybe not.
Did you find a solution. I’m in the same state than you with a H61F6 Govee Strip Light 2 Pro. I believed that it was compatible.
Here is what chatgpt say : Govee Strip Light 2 Pro uses the proprietary RGBIC+ technology (often based on addressable LEDs like Govee G1151 or similar), with an undocumented protocol that is not compatible with the WLED standard.
In summary: WLED is not compatible with the Govee Strip Light 2 Pro strip without significant modifications
Is it true ?
Unfortunately, I believe it is. Nothing I tried worked. I found a similar strip light on AliExpress (china special) that I have found to work well through testing. I plan on repurposing my Govee strips to my office where i only want lighting effects but nothing special. Sorry bud.
Sadly in my case the govee controller died so i wanted to use wled as replacement.
So i need more strip led :wink:
Thc for the reply
