hello dear community,
I have problems connecting with wled via esp32.
I manage to connect to wled from the phone as on the computer. No worries at this level. when I plug the led strip into the esp32, only the 6th led lights up green.
Tu
can anyone help me?
ALDIY
June 24, 2023, 7:37pm
2
Did you follow the wiring here Getting Started - WLED Project
yess I have .
red wire to VIN
White wire to GND
green to D4
in the préférences, GPIO is 2
I dont know What I Ă m doing wrong
ALDIY
June 24, 2023, 9:16pm
5
You could take a picture of your setup , might be others could better help that way
Here my board and the led preferences…
ALDIY
June 25, 2023, 2:45pm
8
On this esp32 D4 is GPIO4 ( Not GPIO2 ) . If you face more issues then use GPIO16 ( it is marked D16 on your board )
There are several versions of ESP32 it seems yours is 3.3v if you use 5v it won’t last long.
I’ve made the same mistake in the past.
Tryphon
September 17, 2023, 6:27pm
10
The problème is solved.
I have cut the connnector from the strip and solder direct l’y to the esp and it works fine.
Still in 5volt,from the computer.
Do you mind that i should connect it in 3.3v? How I can do it ?
Jinx
September 17, 2023, 8:28pm
11
You are good. No need to change your setup.
